Often I will save changes to a report design, deploy reports, then run the report on the front end but the changes won't display. I try deploying again using the DeployAllReportsToSSRS.ps1 but still no changes appear. Then I'll build models, no changes. Restart IIS, no changes. Is there anything that I can do to get my report changes to show?
Here's the output from deploying reports, no errors thrown:
Build started 02/24/2023 16:58:16.
Build step: Metadata validation started. Time: 02/24/2023 16:58:16
Build step: Metadata validation completed (550 ms). Time: 02/24/2023 16:58:17
Build step: Report RDL generation started. Time: 02/24/2023 16:58:17
Build step: X++ compilation started. Time: 02/24/2023 16:58:17
Build step: Report RDL generation completed (399 ms). Time: 02/24/2023 16:58:17
Build step: X++ compilation completed (2888 ms). Time: 02/24/2023 16:58:20
Build step: Database synchronization started. Time: 02/24/2023 16:58:20
Build step: Database synchronization completed (20445 ms). Time: 02/24/2023 16:58:40
Build completed (23907 ms). Time: 02/24/2023 16:58:40
Application pool recycling check started. Time: 2/24/2023 4:58:40 PM
Application pool recycling check completed (26114 ms). Time: 02/24/2023 16:59:06
Deploy Reports started 02/24/2023 16:59:06.
Deploying reports to
http://127.0.0.1:80/ReportServer
Deploying rdl files for report DFWSalesQuotation :
DFWSalesQuotation.Report.rdl
Deploy Reports completed (1373 ms). Time: 02/24/2023 16:59:08
