Hi Mark,
I have not seen this behavior myself, but perhaps this helps you in the right direction.
Quality orders with type inventory indicate that the quality order has been manually created. Perhaps you can find out what user created these and see if you can reproduce this? When creating quality orders manually, it's also possible to change the type from Inventory to Production, so I believe all five QO's you mention have been created manually.
To maybe help solve the issue, are the test groups the same for all quality orders that removed the inventory? It sounds silly, but is there a chance this is a different test group that results in an inventory status that you don't see because of a(n advanced) filter?
Kind regards,
Arnold
Kind regards,
Arnold de Vries
Operational/ERP support at Abacus Medicine B.V.
Alkmaar, Netherlands
Sent: Dec 29, 2022 01:10 PM
Subject: Quality Order Are Removing Inventory
Hello Fellow AX People,
We are seeing quality orders that are removing inventory. What can cause this? We're at a loss to gain insight online.
None of the Test Groups have the 'Destructive Test' flag turned on. We do not see any fields available for the quality order or the QO lines that indicate 'Destructive Test' -- we only find this on the Test Group itself. All the quality order tests have passed and the quality orders have been validated. Of the ones we have identified that removed inventory, their test groups have also been used in quality orders that did not remove inventory. 5 of the quality orders have a reference type of 'Inventory'. The others have a reference type of 'Production'. All the 'Inventory' reference types removed inventory - we are not sure why these were created. Only 3 of 'Production' reference types removed inventory - all others worked as they should have.
We are on AX 2012 R3.
Mark Yankovich
PA
#AX2012R3
#Quality
#Intermediate
#Inventory
