  • 1.  Odata filter query in PowerShell for Dynamics 365
    Posted 28 days ago
    Writing a script for a pipleline and trying to use a filter on a oData query for D365 F&O data entity however can't seem to get it to work. I get results without filter however what i'm trying to do is use a EQ operator to filter based on a string value. I've tried double quotes, single quotes but none seem to work. Below is the specific line from my PowerShell script
    Get-D365ODataEntityData -EntityName SecurityUserRoleAssociations-Token $token -ODataQuery '$filter=UserID eq "ABC"'
    Please let me know if anyone has any suggestions. Thanks!
    Raheel
    Raheel Rao
    Hickory Farms
    IL
  • 2.  RE: Odata filter query in PowerShell for Dynamics 365
    Posted 27 days ago
    Have you tried using -eq instead of eq ?
    Thomas Laza
    South Texas Electric Cooperative Inc
    Nursery TX
  • 3.  RE: Odata filter query in PowerShell for Dynamics 365
    Posted 21 days ago
    Hi Thomas,
    Tried that too and unfortunately that didn't work either.
    Raheel Rao
    ECCO
    IL
  • 4.  RE: Odata filter query in PowerShell for Dynamics 365
    Posted 21 days ago
    Is it possible the filter is case sensitive? If so, you might try all caps on the UserID, or some variation of upper case and lower case.
    Thomas Laza
    Nursery TX
  • 5.  RE: Odata filter query in PowerShell for Dynamics 365
    Posted 20 days ago
    It's definitely case sensitive. It should be UserId. Also I'm not 100% on this, but you may need to use single quotes to escape single quotes, so your filter would look like this
    '$filter=UserId eq ''ABC'''​
    Lenny Kaplan
    Warburg Pincus LLC
    New York NY
