  • 1.  Intercompany Sales Order - Cancelling remaining quantity
    Posted 10 days ago
    Hi all,
    I have an intercompany sales order and need to cancel the remaining quantity on a line. I've gone to the original order, selected the required sales lines and clicked "Update line > Deliver remainder", followed by "Cancel quantity". This has resulted in the following Infolog error
    "You are attempting to enter values that will change the source document amounts for this purchase order. Because invoicing of this purchase order has started, you are not allowed to make changes to these values."
    I have been able to cancel the remaining quantities from other lines in the same sales order, so I'm unsure what may be stopping this particular line
    Has anyone seen this error message before and can advise on possible solutions?
    #AX 2012 #Technical #Intermediate #Sales
    Paul Fildes
    Steelite International Ltd
    Stoke-On-Trent
  • 2.  RE: Intercompany Sales Order - Cancelling remaining quantity
    Posted 3 days ago
    An update to this post
    I discovered the error message originated from the class method PurchLineType.checkInvoiceConstaints(). It was triggered by comparing an updated PO line buffer against the original PO line. In my case the difference was the LINEAMOUNT values, the updated PO line value was to 2dp whilst the original line value was to 5dp. Correcting this via a data fix to 2dp along with the corresponding intercompany sales line value, fixed my problem. I was able to successfully cancel the remaining quantity
    Paul Fildes
    Stoke-On-Trent
