We are running the ancient ax 2012 r3 and I am trying to keep it going to with little to no resources. I am needing to get a changed based alert working for the vendor form specific to any changes in the on-hold function. Basically, QA needs to know anytime a vendor's hold status has been changed.
I had it work one time and then started getting the batch job erroring out for change based alerts. All of the errors do refence users who are no longer in the system (many moons ago).
I do not know that clearing this error would resolve my issue, but thinking it would be a good place to start.
The following is repeated multiple times with mutliple user names and processing task.
Infolog for task Change based alerts processing task (5638101201)
Failed to create a session; confirm that the user has the proper privileges to log on to Microsoft Dynamics.
An error occurred while processing event rules for user 'rbaginsk'.
An error occurred while processing event rules.
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.ErrorException' was thrown.
at Dynamics.Ax.Application.EventJobCUDTask.Run() in EventJobCUDTask.run.xpp:line 42
at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
at BatchRun::runJobStatic(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at BatchIL.taskThreadEntry(Object threadArg)
Larry Hunter
Director
Mooney International Corp.
Kerrville TX
