Thanks Drew,
Makes sense as to what I was seeing as well. I may have them use the Return order number or original SO as the LP on return receipt. I did notice that if using the RMA and put away, we can override the LP for future use. This will help them move material much easier without having the LP to verify.
Trent
Trent Aschliman
McWane, Inc.
Birmingham AL
Sent: Jul 22, 2019 11:54 AM
Subject: RMA AND PUT AWAY
Hi Trent,
All registrations through the WHS mobile device require license plate. For an RMA, the thought is you are receiving something that was shipped. So you can receive the outgoing License plate. The other option a lot of our clients use is to register the RMA using the RMA number as the LP. Hope that helps!
Drew
DXC
GA
Sent: Jul 19, 2019 03:34 PM
Is there any way to perform RMA AND PUT AWAY using the mobile device without requiring license plate registration? Can anyone recommend a source for this process for AX 2012 R3?
Thanks.
Trent Aschliman
McWane, Inc.
Birmingham AL
