I do not think you should be concerned with continuity of the PartyID. It is a big, dumb, number that defines uniqueness of entities in the system. While you are loading your Customers, it is possible that someone else is creating a Vendor or a Contact or an Employee or a Legal Entitiy that will use a number in the sequence of PartyIDs that are being created by your Customer Import. Other than uniqueness, it doesn't have any other attibutes.
You should consider the numbers burned and let your good Customer import assign new numbers.
Mark Schurmann
Accounting Systems Manager
Automobile Protection Corp
Norcross GA
Sent: 09-17-2018 03:18 AM
Subject: Party ID
Though this is a requirement as it seems, it is technically not feasible to make any modifications in Party ID in Global Address Book.
Angna Thakkar
Dynamics AX/ D365 - Sr. Project Manager
Synoptek, India
Ahmedabad
Sent: 09-11-2018 12:15 PM
Subject: Party ID
Good day,
Is it possible to reset or edit the Party ID numbers in the Global Address Book?
Thank you.
Faygen Grant
Subject Matter Expert
Bermudez Group Limited
Mt. Lambert
