Open Forum
1.  Customer Invoice not available
Posted 10 days ago
HI
While applying the payment to Customer open invoice, system keep giving the message "Invoice not available for payment" Although its reflecting as open invoice and in the past payments were made to same Customer and it worked, with same set up its not working now
please advise
thanks and best regards
Nazim Lalji
2.  RE: Customer Invoice not available
Posted 10 days ago
​Hi Nazim,
Can you compare the invoice where you have the problem with the one that worked previously in the customer transactions form?
Probably some parameters / date settings, such as the due date, the approval parameter, payment release date, etc. prevent you from selecting it.
Ludwig
Ludwig Reinhard
SYCOR GmbH
Goettingen
3.  RE: Customer Invoice not available
Posted 9 days ago
Nazim,
This transaction has been marked for settlement by someone else in another journal or the open transaction editing.  To find out where it has been marked, you will need to need to navigate to the Customer "Settle open transactions"  (Customer> Collect> Settle> Settle open transactions).  Then using the Inquiry dropdown in the action bar, select specifications.  Using the radio buttons in the VIEW section until you see the transaction in the lower section.  This lower section will tell you what type of transaction it is located in and the voucher/journal number.
Stacy Black
Senior Application Consultant
mcaConnect
Denver CO
