Bill of Lading generation
  • 1.  Bill of Lading generation
    Posted Jan 04, 2019 03:11 PM
    Edited by Justin Cooper Jan 04, 2019 03:29 PM
    Hello!
    We have enabled the parameter in D365 to have the BOL generated when we post a packing slip. This has been a pretty big time saver for us, however we are struggling with the best way to find that BOL after it is generated. Once we post, there isn't anything that comes up that tells us what that BOL # is so that we can go and print/process when necessary. W​e find that we then need to go into the BOL listing, create a filter and filter based on the sales order number.
    Any thoughts on how to easier find that BOL #?
    Justin Cooper
  • 2.  RE: Bill of Lading generation
    Posted Jan 07, 2019 12:13 PM
    Also curious on if the terms and carrier can be pulled in from the sales order during the posting process? We populate that at the header level of the orders but when you go to post the packing slip, the carrier is blank and the terms are defaulted to the presets that we set in the AR params.
    Justin Cooper
  • 3.  RE: Bill of Lading generation
    Posted Jan 08, 2019 08:33 AM
    Justin, can you give a summary of the parameters you configured to enable the BOL?  Did you customization the form?
    Best,
    Chris
    chris south
    SixAxis/ SafeRack
    Andrews SC
  • 4.  RE: Bill of Lading generation
    Posted Jan 08, 2019 08:43 AM
    Hi Chris,
    Sure - I went into AR-->AR Parameters-->Shipments-->BOL-->Selected "Packing slip update" under "BOL" and left the remaining fields as the default values.
    No customization to the form itself.
    Justin Cooper
  • 5.  RE: Bill of Lading generation
    Posted Jan 15, 2019 04:26 PM
    Does anyone have any recommendations or experience with this?
    Justin Cooper
  • 6.  RE: Bill of Lading generation
    Posted Jan 16, 2019 02:51 AM
    I am not very familiar with BOL, but your post prompted me to poke around
    I might have misunderstood your question though..
    On the sales order, "Pick and Pack" tab, under Packing Slip journal, you can view the BOLs that were generated for that order/Packing slip.
    Is that what you are looking for?
  • 7.  RE: Bill of Lading generation
    Posted Jan 21, 2019 03:40 PM
    Zvika,
    Thank you for your response - that is exactly what we were looking for! This makes it much easier to find the BOL after creation.
    Thank you!
    Justin Cooper
