You can create a personalization and apply that personalization globally to all users. The only thing is, there is nothing to prevent them from removing it. Also keep in mind the personalization is for the entire form, so if they have other personalizations on that particular form you will remove them by applying your form personalizations over top.
Esther Paradoski
Ducks Unlimited Canada
Stonewall MB
Sent: Jan 15, 2021 04:40 PM
Subject: Making a Field Manadatory
You are correct Daniel, it is something that is set user by user. I should have made that distinction.
Phil Bickler
IT Director
Virtual Supply, Inc.
Sent: Jan 15, 2021 02:35 PM
Your suggestion looks like a personalization that would only apply to the person making the field required in this manner, unless I'm missing something?
My assumption is that the only way to make a field mandatory for all users would be via an extension.
Daniel Zook
Director of IT
Lehman's
Dalton OH
Sent: Jan 15, 2021 10:59 AM
Hi Amanda,
If you are on Dynamics 365 for Finance version 10.0.12 or above, you can make fields mandatory. Check out link.
https://exploredynamics365.home.blog/2020/09/02/how-to-make-any-field-as-mandatory-required-without-customization-in-microsoft-dynamics-365-finance-and-operations/
Hope this helps.
Phil
Phil Bickler
IT Director
Sent: Jan 14, 2021 10:41 AM
Is it possibly to make a field mandatory on a PO? Looking to make Business Justification mandatory on a Purchase Requisition.
Amanda Fowler
Campus Management Corp.
FL
