  • 1.  Question regarding System Admin\Common\User Groups
    Posted Mar 18, 2021 02:40 PM
    Hi all..
    We are on AX 2012 RTM.  We have 27 user groups created under System Admin\Common\User Groups.  Does anyone know of a way to determine where each user group is being used within the system?  Is some cases, the individual who created the group provided detail for easy determination (Purchase Req Approval Group) but others are vague.  I am wondering if there is a technical way (within AOT?) to determine where these user groups are actually being used.
    Any help and/or ideas are appreciated!
    Thank you!
    Lori Holmes
    [email protected]
  • 2.  RE: Question regarding System Admin\Common\User Groups
    Posted Mar 22, 2021 09:26 AM
    This probably won't answer all your questions, but you can personalize your journal name screen to add the "Private for user group" field to the list.  This will allow you to quickly browse the user groups assigned to the journal names.
    Mark Schurmann
    Accounting Systems Manager
    Automobile Protection Corp
    Norcross GA
  • 3.  RE: Question regarding System Admin\Common\User Groups
    Posted Mar 22, 2021 12:27 PM
    Check the LedgerJournalName table, BlockUserGroupID field.
    In regards to the workflows where a user group may be at play, it'd be best to manually check those. I am not positive if any RTM tables store this info.
    Ian Gorman, PMP, MCSE
    MCA Connect
