I can confirm the RSAT works pretty neat. BUT the setup of the tool and the proper installation is quite a journey.
We needed a technical consultant from our implementation partner to fulfil the steps not written in the instruction.
I can also confirm Patricks input of breakage. You need to use generic Task Guides to run the automated test AND you cannot create existing data. The test will fail. So think properly through your test scenarios.
I say give it some time to reach a higher and more mature state. Then I see some true potential.
We're on D365FO and use RSAT for the monthly upgrade preparation. I can give you a more hands on feedback by the end of April.
Andreas Möerker
SIGVARIS
Sent: 02-18-2019 09:44 AM
Subject: Seeking Automated Testing Tool Input for AX 2012 R3/D365
Cassie,
Microsoft has released the Regression Suite Automation Tool for D365FO:
Regression Suite Automation Tool (RSAT)
This tool allows for extremely customizable tests to be ran using a task recording output as a baseline and an Excel file as the inputs to run it with. It is in active development and getting lots of feedback and updates regularly. It also ties into Azure DevOps testing suites so you get an overview of what tests passed/failed and why.
Sent: 07-13-2018 03:36 PM
Our company is looking at implementing an automated testing solution for Dynamics AX 2012 R3 with eventual upgrade to D365. We would like to have test sets we can run after code changes to help reduce the time it takes to test (currently done manually) and improve quality. We are a large manufacturing company (around 70 mfg. locations) so looking for a tool that will scale well. We have seen demos of Axeptance and Rapise and do like many features they offer. Am looking for any insight from those whom have any experience with any types of automation tools… however if there are any other large mfg. organizations, input would be a bonus!
Cassie Munoz
Masonite International
Tampa FL
