Position Budgeting
  • 1.  Position Budgeting
    Posted 26 days ago
    When using this feature, is it possible to create cost elements based on salaries based on positions in HR/Payroll?
    It seem like in the Cost Element you assign a set dollar amount per Cost Element, and it will not take the salary assigned to that position.
    Jonathan Struble
    Campus Management Corp.
  • 2.  RE: Position Budgeting
    Posted 16 days ago
    Is this question related to AX2012 setup?
    You can setup the budget cost element with a position such as base pay. Are you setting up a base pay budget cost element?
    Can you share some screenshots what type of cost element have you setup in the system?
    Shilpi Thakur
    Dynact Consulting Ltd
  • 3.  RE: Position Budgeting
    Posted 16 days ago
    Shilpi, In the screen shot below, I am able to apply a set amount to all positions I attach to the cost element, but I would like to pull the actuals from the worker's position compensation.
     Thanks!
    Jonathan Struble
  • 4.  RE: Position Budgeting
    We are budgeting based on the actual compensation & benefit enrollments for the individual employee in F&O HR module (using also the cost elements), but to be perfectly honest I dont recall whether there is an element of customization.
    Have you configured the cost elements as well (i.e. linking them with GL, etc)?
    Pi Tauber
    BI Lead & Solution Architect
    Danish Refugee Council
    Copenhagen
  • 5.  RE: Position Budgeting
    I will take a step back and ask you what exactly are you trying to achieve by exporting actuals from the worker's position compensation? Is this for reporting?
    Shilpi Thakur
