Item Reservation in Sales Order creation
  • 1.  Item Reservation in Sales Order creation
    Posted 30 days ago
    Can you guide us about create a sales order without reserve the item?
    Actually we creating sales order and delivery is after 1 month but while creating sales order itself it is reserving the item it will lead to other current documents not posting due to missing inventory.
    #Focus-D365UG/AXUG
    #Sales
    #Functional
    Abrar Ahamed
    Arla Foods - Saudi Arabia
  • 2.  RE: Item Reservation in Sales Order creation
    Posted 30 days ago
    Hi Abrar,
    On the Accounts receivable parameters there is a setting for the reservation to be automatic or manual.
  • 3.  RE: Item Reservation in Sales Order creation
    Posted 30 days ago
    Hi Andre,
    Thanks for Reply
    I Changed sales default values reservation settings in Account receivable parameters as Manual(Find the attachment) but still, once I entered the sales order line while click save auto reservation form(Find the attachment) showing then after click OK it's reserving again.
    is there any way to avoid that auto reservation form?
    Abrar Ahamed
  • 4.  RE: Item Reservation in Sales Order creation
    Posted 29 days ago
    If the SO header is creating with Manual reservation, but you are getting an auto reservation when keying the SO line, then you should check the Reservation parm on the Item Model Group associated with the Item you have keyed to the SO line.
    Agility Business Solutions
  • 5.  RE: Item Reservation in Sales Order creation
    Posted 27 days ago
    Hi Colby,
    I changed settings as a Manual in the Item model group settings now it's not showing Auto reservation form for sales order line and the item also not reserving in sales order line but auto reservation does not work :-( for inventory transactions like Inventory adjustment, Transfer journal, etc.
    Actually I want manual reservations only for a sales order, not other menus.
    Abrar Ahamed
  • 6.  RE: Item Reservation in Sales Order creation
    Posted 28 days ago
    ​The module parameter is technically just a default onto your sales order header, and from there to the lines.
    Thus - on an order your testing, you'll want to make sure the line value for reservation is set to Manual as you test. If you were testing with an order created prior to your setting of the module parameter, it will likely still have it's header value set to Automatic, thus causing your lines to get set that way regardless of the module parameter.
    Tony Zeigler
  • 7.  RE: Item Reservation in Sales Order creation
    Posted 27 days ago
    Hi Tony,
    Thanks for the reply,
    Actually I created a new sales order after changed the settings as Manual in Accounts receivable parameters but still while click Save it's showing Auto reservation form.
    Abrar Ahamed
  • 8.  RE: Item Reservation in Sales Order creation
    Posted 27 days ago
    ​Check the reservation value on the line. As another poster mentioned, it could be picking up a value from the item as well. I believe if it has, the line will end up with a setting of automatic.
    If the line is set to automatic, you can check the item settings, and the header setting, to see which one could be causing the issue.
    If the line is not set to automatic, it may be time to get a programmer to debug - as I suspect you have some custom code in place.
    Good luck tracking it down :)
    Tony Zeigler
