AX 2012 R2 (Error Attempting Register Picking List)
  • 1.  AX 2012 R2 (Error Attempting Register Picking List)
    Posted 16 days ago
    Greetings,
    I have a customer that is receiving this error and I have no resources in which to diagnose or repair.
    Has anyone seen this before?
    ERROR: #1463 - An error occurred while attempting to register a picking list line for item "000711-V01-5/ 38/ M6/ W7.5-GYTL"
    "WMSOrderTrans record ID {0} is no longer valid and cannot be registered." ****
    Rick Smith
    Integration Specialist I
    TrueCommerce
    Seven Fields PA
  • 2.  RE: AX 2012 R2 (Error Attempting Register Picking List)
    Posted 16 days ago
    typically speaking when i see errors like this, it is because the code in question failed to retrieve a record.  Your best bet probably is to put a breakpoint on the info class add method and debug it to see where the error occurs and determine what condition caused it (you could also double click on the error and it may go to the line in question that threw the error which would save some time.)
    Rich Wasson
    Senior Developer
    West Chester OH
