Extract vendor master data
  • 1.  Extract vendor master data
    Posted 25 days ago
    Any suggestion for extracting Vendor master data in one Excel work sheet which includes everything which is in vendor form: like Vendor #, Name & Address, phone and email, Tax ID number, etc etc
    Thanks and regards​
    Nazim Lalji
    Dynamics AX Analyst
  • 2.  RE: Extract vendor master data
    Posted 24 days ago
    Hi Nazim,
    What exact version of Microsoft Dynamics are you using? As of version AX2012 R2 with CU7 and Dynamics 365 FO, you can use data management to export vendors using Data Import Export Framework/Data Management. In Dynamics 365 for Operations, you can also use the feature 'Open in Excel' and add more columns to get the desired list.
  • 3.  RE: Extract vendor master data
    Posted 24 days ago
    HI Andre
    its AX 2012 R3 CU12
    Require to export Master data from AX to Excel
    thanks and regards
    Nazim Lalji
    Dynamics AX Analyst
    Nazim Lalji
    Los Angeles CA
  • 4.  RE: Extract vendor master data
    Posted 24 days ago
    Edited by Colby Gallagher 24 days ago
    Hi Nazim,
    You can expose the AOT query "VendTableCube" to the Excel add-in at Org admin -> Setup -> Document Mgmt -> Document Data souces.
    When you connect to this query in Excel via Dynamics AX tab in ribbon ->  Add-Data -> Add-Data, right mouse click on the top level table -> Properties -> Show calculated fields, and you will also get all display methods for the tables in the query, one of which is Telephone.  The rest of your fields should be there.
    Agility Business Solutions
  • 5.  RE: Extract vendor master data
    Posted 24 days ago
    Either using DIXF or a straight SQL query would probably be easiest, both have the ability to be exported in an Excel format.
  • 6.  RE: Extract vendor master data
    Posted 24 days ago
    What do you mean by "everything"?  An SQL "Select * from VendTable" works in AX2009, It doesn't pick up contacts or  secondary addresses, or multiple state tax IDs, but it pulls all data that applies one-to-one with any vendor.
    Robert Menschel
    Lead Systems Engineer
    HD Supply Repair & Remodel
    Roseville CA
  • 7.  RE: Extract vendor master data
    Posted 23 days ago
    This really depends on the version you are using, and how often you need to extract the data.
    You can open vendor details, Select all (Ctrl-A), Copy (Ctrl-C) and Paste into Excel. You will get duplicate columns of what is contained in the overview, plus a lot of stuff you are not interested in.
    In AX2012 or D365, look for a view, which will have pre-built links (joins) to related tables. This would be my first choice.
    If you want to write a sql query yourself, you will​ learn a lot about table structures - I've found this handy in navigating: https://alexdmeyer.com/ax2012erd/
    Mark Prouty
    Programmer / Analyst
    ANGI Energy Systems
    Janesville WI
  • 8.  RE: Extract vendor master data
    Posted 23 days ago
    Do you have any custom fields that could be a little more tricky?
    Crystal Ahrens
    Kodak Alaris Inc.
    Albion NY
  • 9.  RE: Extract vendor master data
    Posted 22 days ago
    Hi Nazim,
    if you give me all the fields you need, I can pull together an Atlas Query and upload it for you to use.
    Other thing is like someone else said. SQL select * on vendtable for most of the content
    rgds
    Carsten
    Carsten Schoenberg
    FITPRO SOLUTIONS
    Hamburg
