How to make sure (check) Entity Store connect to which server and database
  • 1.  How to make sure (check) Entity Store connect to which server and database
    Posted Mar 27, 2019 02:21 AM
    Hi guys,
    How to make sure my F&O Entity Store connect to which server and database ? Beside check webconfig file. So, is there a menu inside F&O itself saying when I refresh Entity Store, it will go to that.
    I'm creating Power BI Analysis using Direct Query to F&O, but got confuse because  when I Refresh Entity store, sometime it reflected to my other server and DB. I have Azure DB that hold the AXDW database and also has Local server.
    Thanks.
    Morgan Fields
    Hunter Douglas
  • 2.  RE: How to make sure (check) Entity Store connect to which server and database
    Posted Apr 01, 2019 11:58 AM
    Here at Dynamics Resources we specialize in Dynamics 365, all versions of AX, and CRM. I ran your question by one of my experts, he wanted me to ask you the following.
    "Could you please share what version of Dynamics you are using? Also know if you are currently working in non-productive environments by designing reports in Power BI? Why do you use the local server?"
    Michael Gonzalez
    Account Executive
    Dynamics Resources
    Venon Hills IL
