Greetings, is there a resource that shows the mapping between entities in ax 2012 to D365? For example Vendors, If I pull the data from ax2012 R3 using the DIEF functions, how do the columns map to the entity in D365? Not all the fields have the same or similar names. Is there a map that shows this field in the ax 2012 entity maps to this field in the D365 entity.
Eric Bassett
FORCE America
Burnsville MN
