Exchange Rate Provider Lookup
  • 1.  Exchange Rate Provider Lookup
    i have add a new Exchange Rate Provider. But if i want to add it in the Form the Lookup does not open. It looks like the function searchForDotNetProviders in the ExchangeRateProviderRegistration get no result.
    private ExchangeRateProviderSearchResults searchForDotNetProviders()
    return Microsoft.Dynamics.AX.Application.FinancialManagement.Currency.ExchangeRateProviders::SearchForProviders();
    Does somebody have an idea?
    Torsten
    Torsten Finndorf
    GOLDBECK
    Treuen
  • 2.  RE: Exchange Rate Provider Lookup
    Please follow the steps in the manual to add an Exchange Rate Provider.
    https://www.microsoft.com/en-au/download/confirmation.aspx?id=36047
    From page 11, indicate how to work with the process.
    On page 20 you will find the debugging process:
    ExchangeRateProviderRegistration.initialize () - This method searches for providers so that they can be registered by the application. If you can not see your provider in the registration form, start debugging here.
    Michael Gonzalez
    Account Executive
    Dynamics Resources
    Venon Hills IL
  • 3.  RE: Exchange Rate Provider Lookup
    Hi Torsten,
    Did you do a CIL build and possible restarted AOS machines?
  • 4.  RE: Exchange Rate Provider Lookup
    Thank's some changes in the initialize method fix the Problem.
    Torsten Finndorf
    GOLDBECK
    Treuen
