Can you confirm the chain of events you are describing is as follows:
1. FTI recorded in CAD
2. check receipt recorded in USD and settled against the CAD invoice, partially settling it.
3. user ran functionality of
foreign currency revaluation in the GL module (GL > Periodic Tasks > Foreign Currency Revaluation).
4. The customer observes, that although the USD payment is "closed"/"settled" it still gets revalued
If this is indeed what happened than the root cause of your problem is that you are NOT supposed to be using the GL Fx Revaluation to revalue AR balances.
There is an AR specific FrX revaluation functionality that needs to be run separately and used on open AR balances.
There are several important reasons why using the GL revaluation for AR or AP balances is wrong, and one of the major reasons is that just like you are experiencing the GL process does not "recognize" closed balances, so it will continue to try to revalue full settled balances forever.
If this is indeed the case there are several configuration steps you need to take in order to exclude AR/AP from the GL revaluation functionality ,and turn on the AP/AR specific revaluation.
Sent: Dec 11, 2020 11:33 AM
Subject: Foreign currency partial payment posted against local currency invoice being revalued
Hi UG!
My client is using AX2012 R3 CU8.
They issued a FTI to a customer in CAD (the system accounting currency).
The customer partially paid the invoice with a USD cheque.
My client revalues GL accounts at month end and this USD transaction is being revalued, however, they expected that the CAD value should have been 'locked in' when the transaction was recorded.
Has anyone else encountered this? Is this expected system behaviour? Any suggestions on how to prevent this transaction from revaluing?
Thanks!
Josh Bazin, CPA, CMA
(they/them)
Functional Analyst, NTT DATA
Edmonton AB
