Update Conflict : The Standard Cost does not match with the Financial Inventory value after the update.
  • 1.  Update Conflict : The Standard Cost does not match with the Financial Inventory value after the update.
    Posted Mar 21, 2021 01:43 AM
    Edited by Abrar Ahamed Mar 21, 2021 01:43 AM
      In the D365 WMS process while complete the work sometimes we facing issues like Update Conflict: The Standard Cost does not match with the Financial Inventory value after the update.As per Microsoft its generic issue Troubleshoot cost management - Supply Chain Management | Dynamics 365 and one of the solution is Repost the Document but sometimes its got posted after a long time.
    As per the Error message any one of the items in the work order facing an issue with updating the cost and the error message(Find the attached image) not showing any item number. Is there any way to find the item number facing the issue and how all other clients handling this issue?
    #Focus-D365UG/AXUG #WarehouseManagement
    Abrar Ahamed
    Arla Foods - Saudi Arabia
  • 2.  RE: Update Conflict : The Standard Cost does not match with the Financial Inventory value after the update.
    Posted Mar 21, 2021 06:33 PM
    Abrar,
    It may be worthwhile to open a case with Microsoft. They've assisted my clients with determining which itemID encountered this rounding error.
    Ian Gorman, PMP, MCSE
    MCA Connect
  • 3.  RE: Update Conflict : The Standard Cost does not match with the Financial Inventory value after the update.
    Posted Mar 23, 2021 02:18 AM
    Hi Ian,
    Thanks for the reply.
    Actually, we created a ticket with Microsoft as per them it's a generic issue and not able to identify the item and it's fixed in version  10.0.14. We plan to upgrade pu40 v10.0.16 this week. I will observe and if still facing an issue I will recheck with Microsoft.
    But as per you, they assisted your clients to identify the items so again I will recheck with Microsoft.
    Abrar Ahamed
