unable to run Finanical reporting (MR) in D 365
  • 1.  unable to run Finanical reporting (MR) in D 365
    Posted 22 days ago
    Hi All
    Unable to create new report nor able to edit the existing default reports in Financial Reports. Any click creates Report Designer Application. Clicking Report Designer application error out with message "Application cannot start, contact application vendor"
    any one have came across with any error message using FR for the first time in D 365
    please advise
    thanks and kind regards
  • 2.  RE: unable to run Finanical reporting (MR) in D 365
    Posted 21 days ago
    Najeem,
    Use the Edge browser, it doesn't work with Chrome.
    Financial reporter is a 'one-click' application.
    Russ Worth
    Russell Worth
    D365 System Administrator
    Hunting Energy Services
  • 3.  RE: unable to run Finanical reporting (MR) in D 365
    Posted 20 days ago
    Najeem,
    This creates a popup which may be an issue on your browser.  The OneClick extension (For Chrome & Edge I use the Meta4 ClickOnce Launcher).
    Stacy Black
    Senior Finance Consultant
    MCA Connect
    Mukilteo WA
  • 4.  RE: unable to run Finanical reporting (MR) in D 365
    Posted 20 days ago
    More detailed info here:
    Financial reporting overview - Finance | Dynamics 365 | Microsoft Docs
    Section : Troubleshooting issues opening Report Designer
    • If you are using a Chrome browser, you must install a ClickOnce extension in order to download the Report Designer client. If you are running Chrome in incognito mode, make sure the ClickOnce extension is enabled for incognito mode. For more information about the Chrome ClickOnce Extension, see System requirements for cloud deployments.
    • If you are using Microsoft Edge with a Chrome browser, you do not need to install a ClickOnce extension for Edge Chromium. However, you must enable the ClickOnce option in order to download the Report Designer client. If you are running incognito mode, make sure the ClickOnce extension is enabled for incognito mode.
      1. Open a new browser in Microsoft Edge.
      2. Enter edge://flags and select Enter.
      3. Search for the ClickOnce Support option or use this direct link: edge://flags/#edge-click-once.
      4. Set the drop-down menu option to Enabled.
      5. Select Restart Browser.
    Jonathan Howe
    Head of IT
    Cross Manufacturing
    Bath, UK
