Windows Server 2016 - AX 2012 R3
  • 1.  Windows Server 2016 - AX 2012 R3
    Posted Jul 02, 2019 01:08 PM
    We are in the process of upgrading our windows servers to 2016. We are currently running AX 2012 R3 CU8. Does anyone know if this CU is supported? My research indicates that we may need to upgrade to at least CU11. Is there any MS documentation on the compatibility?
    Michael
  • 2.  RE: Windows Server 2016 - AX 2012 R3
    Posted Jul 02, 2019 01:17 PM
    Please refer below link(check section system requirements) which has installation details of AX 2012 R3 CU8
    (Installation Guide for Microsoft Dynamics AX 2012 R3 Cumulative Update 8)
    https://www.microsoft.com/en-us/download/details.aspx?id=44953
    Chaitanya Golla
    Lead Architect
  • 3.  RE: Windows Server 2016 - AX 2012 R3
    Posted Jul 02, 2019 01:37 PM
    Thanks Chaitanya,
    We are already running CU8 and I dont see the section you point out in the document. I just found the document below and looks like we need a minimum of CU12 to run on Windows Server 2016.
    https://www.microsoft.com/en-nz/download/confirmation.aspx?id=11094
    Michael Woods
    The Safariland Group
    Jacksonville FL
  • 4.  RE: Windows Server 2016 - AX 2012 R3
    Posted Jul 02, 2019 02:01 PM
    I am referring to the section highlighted below.Anyway if you click on the hyperlink "System requirements for Microsoft Dynamics AX 2012" it is leading to same document you mentioned.
    Chaitanya Golla
    Lead Architect
  • 5.  RE: Windows Server 2016 - AX 2012 R3
    Posted Jul 02, 2019 02:14 PM
    Thanks Chaitanya,
    Much appreciated.
    Michael
    Michael Woods
    Jacksonville FL
