Odata Authentication
  • 1.  Odata Authentication
    I am creating an MVC web site that integrates with Finance and Operations through the Odata services.  When I execute the site on the development server (localhost) everything works properly.  However, when i publish the site to an IIS web server it is unable to authenticate with Azure AD.  Interestingly, is I set up a proxy to use fiddler on the server to diagnose the issue, the application begins working.
    Any ideas on how to resolve the issue would be greatly appreciated.
    Scott Anderson
    Nomaco
    Zebulon NC
  • 2.  RE: Odata Authentication
    Scott, A bit more information on the authentication methods would be helpful. Are you using the App Authorization Code method? https://docs.microsoft.com/en-us/previous-versions/azure/dn645542(v=azure.100)?redirectedfrom=MSDN
    On the Fiddler issue - Auth methods are designed to break when you have a man-in-middle like Fiddler, to prevent attacks, so Fiddler is not always a great tool for troubleshooting auth issues.
    https://docs.microsoft.com/en-us/dynamics365/fin-ops-core/dev-itpro/data-entities/services-home-page
    A reference project Microsoft provides: https://github.com/Microsoft/Dynamics-AX-Integration/tree/master/ServiceSamples/AuthenticationUtility
    Brent Hawthorne
    Sr Manager of Application Development
    Daisy Brand
    Dallas TX
  • 3.  RE: Odata Authentication
    Hi Brent, thank you for your reply.  We are using the App Authorization method with Client ID and Secret.  Everything I have read indicated the issue is likely related to the redirect address and it works locally and via Fiddler because bother reference themselves as localhost - which AAD makes exceptions for.  Let me know if you agree.
    The question that comes out of that but I have not found a direct reference to is "In order to get ClientID/Secret to work does the redirect address have to be globally accessible (IE: not behind a firewall or NAT).
    Scott Anderson
    Nomaco
    Zebulon NC
