Fiscal year closing error message
  • 1.  Fiscal year closing error message
    Posted 19 days ago
    Hi All
    While running a fiscal year close from path
    General Ledger > Periodic > Fiscal year close > opening transactions
    receiving the following error message:
    "The Fiscal year that ends with the date 12/31/2019 is already closed"
    However we can close Fiscal year as many times as require in AX 2012
    please advise
  • 2.  RE: Fiscal year closing error message
    Posted 19 days ago
    Najeem,
    Assuming you're on F&O.
    Step 1 - Go to GL parameters, ledger tab, 'fiscal year close' drop-down. Make sure 'set fiscal year status to permanently closed' is set to NO.
    Step 2 - When you're closing your fiscal year, there's an 'undo previous close' flag.. Select YES then click OK.
    Ian Gorman, PMP, MCSE
  • 3.  RE: Fiscal year closing error message
    Posted 18 days ago
    Hello Najeem JanatAli,
    I am not sure what version of Dynamics you are on but first check your General ledger parameters> General> Fiscal year close to see if you have flagged to 'Delete close-of-year transactions during transfer' to a yes.  This option allows the system to delete prior closing/opening transactions when a new closing is created.
    Also are you getting a full stop or just a warning?
    Stacy Black
    Senior Application Consultant
    MCA Connect
    Denver CO
  • 4.  RE: Fiscal year closing error message
    Posted 16 days ago
    HI All
    its AX 2012 CU12
    From Ledger removed Account structure and fiscal calender and re aded a new fiscal calender, it work for now. Not satisfied with this trick
    Looking for a reason and proper solution
    Thanks and kind regards
  • 5.  RE: Fiscal year closing error message
    Hello Najeem,
    1.  Can you tell me if the periods for last year are in a state of On Hold or Closed?
    2.  In your General ledger parameters> Ledger> Fiscal year close do you have the flag turned on for 'Set fiscal year to permanently closed'?
    Stacy Black
    MCA Connect
    Mukilteo WA
