Expense report error: "Dimension value XXX is not active." (AX 2012)
  • 1.  Expense report error: "Dimension value XXX is not active." (AX 2012)
    Posted 24 days ago
    Hi everyone!
    I have encountered a problem where, if a financial dimension value has an "Active from" date defined, users receive an error message that the value is "not active" when they try to enter/select the value on an expense report line (details below).  Has anyone else experienced this? And is there a solution?
    Thanks in advance!
    When entering an expense report line, users receive an error message that a financial dimension value is "not active":
    However, the financial dimension value is active:What I discovered from testing is that removing the Active from date allows the value to be used on the expense report line.
    #AX2012​​ #Finance
    Paul Ceely
    Group ERP Functional Support Specialist
    Britax
    SC, United States
