Hi everyone!
I have encountered a problem where, if a financial dimension value has an "Active from" date defined, users receive an error message that the value is "not active" when they try to enter/select the value on an expense report line (details below). Has anyone else experienced this? And is there a solution?
Thanks in advance!
When entering an expense report line, users receive an error message that a financial dimension value is "not active":
However, the financial dimension value is active:
What I discovered from testing is that removing the Active from date allows the value to be used on the expense report line.
#AX2012 #Finance
Paul Ceely
Group ERP Functional Support Specialist
Britax
SC, United States
