Reverse Timesheet
  • 1.  Reverse Timesheet
    Posted 22 days ago
    Edited by Kamar Wilks 22 days ago
    Hi All
    I have a case where a user entered incorrect information in his timesheet. It already went through the workflow and has been posted.
    Is there a way to reverse this posting so he can enter the correct information?
    Kamar Wilks
    BlueCrest Inc
    Danbury
  • 2.  RE: Reverse Timesheet
    Posted 22 days ago
    Hi Kamar,
    A situation like this usually requires the completion of a correcting timesheet that will reverse the incorrect hours and add in the the correct hours.  Once posted, most things in the system are pretty well permanent.
    Ben Morgan
  • 3.  RE: Reverse Timesheet
    Posted 22 days ago
    Thank you Ben
    Good to know. I'll try your suggestion.
    Kamar Wilks
    BlueCrest Inc
    Danbury
  • 4.  RE: Reverse Timesheet
    Posted 22 days ago
    Hi Kamar,
    If a timesheet has been posted incorrectly then you can use the project adjustment functionality to post the related transactions where they should have gone. Please review this MS Doc. page.
    https://docs.microsoft.com/en-us/dynamicsax-2012/appuser-itpro/adjust-transactions
    Using this method there is a full audit trail of the amendments and you can amend the majority of fields on the project transactions (E.g. Change Project, Category, Line Properties etc).
    Hope that helps.
    KR
    Mark
    Mark Bailey
    Portsmouth
  • 5.  RE: Reverse Timesheet
    Posted 21 days ago
    Hi Kamar,
    Every employee in our organization has to complete a monthly timesheet, so this situation happens to us often. The easiest way is for the user to enter a credit timesheet to reverse the posted one and a new timesheet the way it should have been entered and the user is making the correction themselves, instead of an administrative position.
    Esther Paradoski
    Ducks Unlimited Canada
    Stonewall MB
  • 6.  RE: Reverse Timesheet
    Posted 19 days ago
    Thanks, Esther
    This is similar to reversing expenses.
    Kamar Wilks
    BlueCrest Inc
    Danbury
