Creating a custom form/dialog in AX 2012
  • 1.  Creating a custom form/dialog in AX 2012
    Posted Nov 18, 2020 06:30 AM
    Hi all,
    I'm looking to create a custom form/dialog which would prompt the user for a list of shipped shipments and a XML filename. I am new to Form development and would appreciate some advice on how I should proceed.
    I envisage the form to include a non-editable grid, a textbox and a button to allow file browsing. When a user selects a collection of shipments from the grid and specifies a filename in a simple textbox and clicks on a OK button, the form should create an XML file containing field values from the shipment.
    I've reviewed the "tutorial" sample forms in the AOT and cant quite find one suitable to start from. Can anyone advise how I go about this or recommend any good training material that I can use to help me?
    Thanks and regards,
    Paul
    #AX2012 #Intermediate #Technical​​​​​​
    Paul Fildes
    Steelite International Ltd
    Stoke-On-Trent
  • 2.  RE: Creating a custom form/dialog in AX 2012
    Posted Nov 19, 2020 10:26 AM
    Edited by Wes Burke Nov 19, 2020 10:26 AM
    Hi Paul,
    Here's a link that will help you out with the code needed to generate the XML file:
    https://shyamkannadasan.blogspot.com/2016/06/ax-creates-xml-file-in-x-containing.html
    Here is one that will help you with creating your dialog box:
    https://docs.microsoft.com/en-us/dynamicsax-2012/developer/using-classes-to-create-a-dialog" target="_blank" rel="noopener"> https://docs.microsoft.com/en-us/dynamicsax-2012/developer/using-classes-to-create-a-dialog
    Good luck!
    Wes
    Wes Burke
    Senior Business Intelligence Analyst
    Miltope Corporation
    Hope Hull AL
  • 3.  RE: Creating a custom form/dialog in AX 2012
    Posted Nov 20, 2020 05:17 AM
    Hi Wes,
    Thanks for your message and the suggested links. I have so far, created a Popup form, containing a grid which is populated by a View. I also have a StringEdit field associated to the "FilenameSave" EDT which allows me to prompt for an XML file.
    I'm now looking at processing the selected grid lines to save the data to the XML file in the form's closeok() method
    Thanks again
    Paul
    Paul Fildes
    Stoke-On-Trent
  • 4.  RE: Creating a custom form/dialog in AX 2012
    Posted Dec 08, 2020 06:52 PM
    Hi Paul,
    Here is an example 'Job' of how you can populate the XMLDocument class with XML nodes and values in those nodes. You can create a 'Job' in the AOT and test building out your xml and saving it to a file.  Once you have that working you can copy this code into your closeOk() method if you would like.  You are going to want to write code like this:
    while select myDataSource
     //put code here to populate the oDoc object.  See the other links for examples on how to do this.
    odoc .save('C:\\Temp\\MyXMLFile.xml');
    static void testXml(Args _args)
        XMLDocument odoc = new XMLDocument();
        XMLNODE oNode;
        str test;
        str result;
        XMLTextWriter writer;
        writer = XMLTextWriter::newXml();
        test = 'Test';
        writer.writeElementString('Something',test);
        writer.close();
        odoc.loadXml(writer.writeToString());
        onode = odoc.selectSingleNode('Something');
        if(onode)
            info(strfmt('%1',onode.text()));
    Here are some additional helpful links:
    http://axzaptech.wordpress.com/2010/11/24/create-xml-and-write-to-file-in-dynamics-ax/
    http://learnax.blogspot.com/2010/01/x-code-to-write-data-to-xml-file.html
    Peter Ramer
    Manager
    RSM
    Greenwood Village CO
