Due to/ Due from account for consolidation & elimination
  • 1.  Due to/ Due from account for consolidation & elimination
    Posted Nov 21, 2018 07:58 PM
    Hi All
    We are using a shared chart of account. we have a same account number for Due to & Due from in both the intercompanies. Eg
    Company ABC
    Account# : 230100 :  Due to / from company ABC/ XYZ
    Company XYZ
    Account # : 230100 :  Due to / from Company XYZ/ ABC​
    Due we require a Due to / Due from different account for consolidation and elimination. Or the same account is ok and will work
    Please advise your expertise
    Thanks and best regards
    Nazim Lalji
    Dynamics AX Analyst
  • 2.  RE: Due to/ Due from account for consolidation & elimination
    Posted Nov 23, 2018 01:52 PM
    You can use the same account, however doing so will add some overhead to reconciling
    Bradley Bertchie, PMP
    D3FO Project Manager / Financial Functional Consultant
    Edgewater Fullscope
    Denver CO
  • 3.  RE: Due to/ Due from account for consolidation & elimination
    Posted Nov 23, 2018 11:35 PM
    Thanks Bradley for the response
    Please can you advise what does that means add some overhead to reconciling or if you can provide some example would be great
    Nazim Lalji
    Dynamics AX Analyst
  • 4.  RE: Due to/ Due from account for consolidation & elimination
    Posted Nov 26, 2018 01:45 AM
    This approach (having single account per 2-company relationship) will not scale very well.
    For 3 companies you'll need 3 accounts (2+1)
    For 4 companies you'll need 6 accounts (3+2+1)
    For 5 companies you'll need 10 (4+3+2+1)
    and so forth
    For a small set of companies it might be somewhat useful approach as when consolidating you would expect each account to be exactly 0, so can save you some elimination journals
