Dates must be in same fiscal year
  • 1.  Dates must be in same fiscal year
    Posted 16 days ago
    Hi All
    I am unable to run Trial balance, receiving following error message
    From date is in fiscal year 2019. To date is in fiscal year 2019. Dates must be in same fiscal year
    any suggestion
    thanks and kind regards
  • 2.  RE: Dates must be in same fiscal year
    Hi Nazim,
    That message is thrown when the from date and the to date you are trying to view the TB by are in different fiscal years.
    E.g.   Fiscal year is  01/04/19 - 31/12/19
    TB
    From  = 01/02/19
    To       = 31/05/19
    AX/D365 will throw an error message as you are trying to report on 2 fiscal years.
    TB
    From = 01/02/19
    To     =  31/05/19
    AX/D365 will not throw an error as the dates are in the same financial/fiscal year
    Have a look at the periods in the financial calendar in the GL -> Set up area and try to report on dates within a calendar year.
    Kind Regards
    Mark
    Mark Bailey
    Portsmouth
  • 3.  RE: Dates must be in same fiscal year
    Nazim,
    The error is related to the calendar chosen when the legal entity was setup.  If the legal entity had a Gregorian calendar setup in the Ledger, then the periods that could be requested in the Parameters of the Trial balance would be from 1/1 through 12/31.  However, if you are trying to report on the Gregorian calendar and your legal entity has a fiscal year from 4/1 through 3/31 you will not be able to get this from native AX, you would be better off to use Management reporter and modify the base periods/years to report the time frame you are looking for.
    Hope this helps,
    Stacy Black
    Senior Application Consultant
    MCA Connect
    Denver CO
