Automatic release to warehouse for a Load
  • 1.  Automatic release to warehouse for a Load
    Posted 20 days ago
    Good afternoon,
    Is there a way to automatically release to warehouse a Load? Apparently, the only way to accomplish that is to manually "Release to Warehouse" an outbound Load through the Load Planning Workbench.
    I am looking for a feature similar to "Process outbound shipments" menu.
    Thanks in advance,
    Pierluigi
    Pierluigi Montanari
    DXC Technology
    Chesterfield
  • 2.  RE: Automatic release to warehouse for a Load
    Posted 19 days ago
    Good Afternoon,
    Depending on what you are wanting to release, there are options. In AX2012R3, the version we are currently on, under the warehouse management module. If you go to Warehouse management > Periodic > Automatic release of sales order. This allows you to release any, and as many, sales orders that are ready for warehouse. Although this is a manual process, it is a lot faster than load planning workbench. The same function is available in D365 as well. It is located in Warehouse management > Release to warehouse. You can also set up a batch job to release "ready for warehouse" sales orders to drop automatically. This is the automatic release which you could setup as a batch job with a search criteria. This will then released the orders at the regular interval that you specify. This can be handy to avoid a user having to manually release orders.
    Check out this link
    Microsoft Docs
    Hope this helps!
    Kathy Hance
    ERP Support/AX MFG Steward/ Inventory Coordinator
    Bush Brothers & Company
    Knoxville TN
  • 3.  RE: Automatic release to warehouse for a Load
    Posted 18 days ago
    Good morning,
    And thanks a lot for your suggestion! The business process here is slightly different, as the sales orders are planned and potentially grouped to loads. Once all the loads have been confirmed, release happens to the warehouse.
    In fact, following your suggestion, I could release the Sales Orders linked to a Load not yet released - I think this should be possible with the joins.
    Kind regards
    Pierluigi
    Pierluigi Montanari
    DXC Technology
    Chesterfield
