Is it possible to stop a compile with cross references and how to?
  • 1.  Is it possible to stop a compile with cross references and how to?
    Posted Nov 21, 2018 09:17 AM
    Hello, We will be doing a compile with cross references in preparation for archiving our old data. Does anyone know if a compile can be stopped and if so, how to do it?
    We are on AX 2009  Roll up RU 6
    Build number
    5.0.1500.3761
    Thank you
    Cristina
    Email: cristins@jdbyrider.com
    Cristina Seely
    Accounting Support Business Analyst
    J.D. Byrider
    Carmel IN
  • 2.  RE: Is it possible to stop a compile with cross references and how to?
    Posted Nov 21, 2018 10:42 AM
    Hi Cristina, only way I know of is to stop the AOS.  That said this is not a good thing but you obviously have reasons to consider this.  I would immediately start another compile once you get the AOS back up as your system will not be in a good place till you get a completed compile.
    Good Luck
    Mark Zerr
    AX Technical Analyst
    New Sunshine LLC
    Indianapolis IN
  • 3.  RE: Is it possible to stop a compile with cross references and how to?
    Posted Nov 26, 2018 09:58 AM
    Thank you Mark for the info.
    Cristina Seely
    J.D. Byrider
    Carmel IN
  • 4.  RE: Is it possible to stop a compile with cross references and how to?
    Posted Nov 27, 2018 09:41 AM
    ​Hitting the Control-Break key will interrupt a compile an return control back to user. You should get the prompt "Are you sure you want to cancel this operation?", but it might take a couple minutes.
    I do not know what state this leaves the source code. I would expect that you would want to re-execute a compile as soon as possible.
    If you are updating cross references, you have an option to delete first - I don't know if those roll back to pre-compile state.
    Good question!
    Mark Prouty
    Programmer / Analyst
    ANGI Energy Systems
    Janesville WI
