Print and apply labeling hardware / softwear
Jump to Best Answer
  • 1.  Print and apply labeling hardware / softwear
    Posted Nov 27, 2018 02:45 AM
    ​Hi -
    Looking for a full Integrated with D365 print and labeling system, there are matching the criteria with in food industry. Do you have any references or suggestions ?
    Kent Nørkær Steffensen
  • 2.  RE: Print and apply labeling hardware / softwear
    Best Answer
    Posted Nov 28, 2018 10:20 AM
    Hello Kent,
    Most common solution I see in use under this scenario is Bartender by Seagull. If Bartender makes sense for your needs, you might also want to look at this as well: https://appsource.microsoft.com/en-us/product/dynamics-365-for-finance-and-operations/dsi.9988e1ad-848f-424d-bb90-0a38df47b57a?tab=Overview - OR- check with To-Increase (here: https://www.to-increase.com/) to see if they have migrated their adapter for Bartender over to D365FO.
    Jack Moran
    Director of Industry Solutions
    Columbus
    Greenfield NH
  • 3.  RE: Print and apply labeling hardware / softwear
    Posted Nov 29, 2018 02:03 AM
    Hi Jack,
    Thanks for the reply,
     I will look in to bartender already been around that one, will talk with To-increase as we already are using different integrations from their side.
    Br Kent
    Lantmännen Unibake Holding A/S
    Copenhagen
  • 4.  RE: Print and apply labeling hardware / softwear
    Posted Nov 29, 2018 10:08 AM
    Hi Kent,
    Blue Horseshoe has a Warehouse Automation module which can be used for Print & Apply (and many other MHE integrations).  It's available for AX2012 R2, R3 and D365, and is all built with extensions.
    Microsoft have licensed this IP from us, so we expect it to become part of standard in the next year or two.  You can license it from us until it's released in standard.
    I've included a link below.  If you'd like more info, shoot me an email at aprior@bhsolutions.com
    Thanks, Angus
    Warehouse Automation remove preview
    Warehouse Automation offers embedded MHE integration directly into Dynamics 365 for Operations.
    View this on Warehouse Automation >
    Angus Prior - BHS Amsterdam
