Coverting AX Queries to SQL Queries
  • 1.  Coverting AX Queries to SQL Queries
    Posted Dec 04, 2019 08:12 AM
    Good Morning,
    I have an ongoing project to take one of our reports within AX 2012 and develop and automated job. This involves mostly querying the inventory tables to gather the data together the complication I am having is how to effectively do so. My current query does not generate any records for me now which I believe I am linking the dimension views incorrectly but I have no ideas how these tables should be linked.
    Attached is the report and the table information along with my query that I have been working on.
     Select Top 100 S.ACC, S.[Item Number], S.[Name], S.Physical_Date, S.Remark, S.Quantity, S.[Physical Unit Price], S.Total, S.Dept, S.Line, S.Proj From (
    Select Top 100   Ito.[ItemId] AS 'Item Number',
      Ijt1.[JournalNameID] AS 'Name',
      FORMAT(Its.[DatePhysical], 'MM-dd-yyyy') AS 'Physical_Date',
             Ijts1.[AW_ResolveMemo] As 'Remark',
             Its.[QTY] As 'Quantity',
             Its.[COSTAMOUNTPHYSICAL] As 'Physical Unit Price',
      Its.[COSTAMOUNTPHYSICAL] * Its.[QTY] As 'Total',
             isnull(d_1.DISPLAYVALUE,'') as ACC,
             isnull(d_2.DISPLAYVALUE,'') as DEPT,
             isnull(d_3.DISPLAYVALUE,'') as LINE,
             isnull(d_4.DISPLAYVALUE,'') as RINGI,
             isnull(d_5.DISPLAYVALUE,'') as PROJ
    FROM MicrosoftDynamicsAX.dbo.INVENTTRANS Its
    inner join MicrosoftDynamicsAX.dbo. InventTable It
    on Its.RECID = It.RECID
    inner join MicrosoftDynamicsAX.dbo. InventTransOrigin Ito
    on Its.RECID = Ito.RECID
    inner join MicrosoftDynamicsAX.dbo. InventDim Id
    on Its.RECID = Id.INVENTDIMID
    inner join MicrosoftDynamicsAX.dbo. InventJournalTrans Iss
    on Iss.DEFAULTDIMENSION = Iss.INVENTDIMID
    left join MicrosoftDynamicsAX.dbo.DIMENSIONATTRIBUTELEVELVALUEALLVIEW d_1
    on Its.INVENTTRANSORIGIN = d_1.VALUECOMBINATIONRECID
    and d_1.VALUEORDINAL = 1
    left join MicrosoftDynamicsAX.dbo.DIMENSIONATTRIBUTELEVELVALUEALLVIEW d_2
    on Its.INVENTTRANSORIGIN = d_2.VALUECOMBINATIONRECID
    and d_2.VALUEORDINAL = 2
    left join MicrosoftDynamicsAX.dbo.DIMENSIONATTRIBUTELEVELVALUEALLVIEW d_3
    on Its.INVENTTRANSORIGIN = d_3.VALUECOMBINATIONRECID
    and d_3.VALUEORDINAL = 3
    left join MicrosoftDynamicsAX.dbo.DIMENSIONATTRIBUTELEVELVALUEALLVIEW d_4
    on Its.INVENTTRANSORIGIN = d_4.VALUECOMBINATIONRECID
    and d_4.VALUEORDINAL = 4
    left join MicrosoftDynamicsAX.dbo.DIMENSIONATTRIBUTELEVELVALUEALLVIEW d_5
    on Its.INVENTTRANSORIGIN = d_5.VALUECOMBINATIONRECID
    and d_5.VALUEORDINAL = 5
    left join MicrosoftDynamicsAX.dbo.InventJournalTable Ijt1
    on Ijt1.LEDGERDIMENSION = d_1.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo.InventJournalTable Ijt2
    on Ijt2.LEDGERDIMENSION = d_2.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo.InventJournalTable Ijt3
    on Ijt3.LEDGERDIMENSION = d_3.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo.InventJournalTable Ijt4
    on Ijt4.LEDGERDIMENSION = d_4.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo.InventJournalTable Ijt5
    on Ijt5.LEDGERDIMENSION = d_5.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo. InventJournalTrans Ijts1
    on Ijts1.LEDGERDIMENSION = d_1.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo. InventJournalTrans Ijts2
    on Ijts2.LEDGERDIMENSION = d_2.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo. InventJournalTrans Ijts3
    on Ijts3.LEDGERDIMENSION = d_3.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo. InventJournalTrans Ijts4
    on Ijts4.LEDGERDIMENSION = d_4.VALUECOMBINATIONRECID
    left join MicrosoftDynamicsAX.dbo. InventJournalTrans Ijts5
    on Ijts5.LEDGERDIMENSION = d_5.VALUECOMBINATIONRECID
    where isnull(d_1.DISPLAYVALUE,'') LIKE '631%') S
    Where Format(CONVERT(date, S.Physical_Date), 'MMMM, yyyy') = 'August, 2019'
    group by S.ACC, S.[Item Number], S.[Name], S.Physical_Date, S.Remark, S.Quantity, S.[Physical Unit Price], S.Total, S.Dept, S.Line, S.Proj​
    Allen Broady
    AWNC
    Attachment(s)
    xlsx
    Sample.xlsx   1007K 1 version
  • 2.  RE: Coverting AX Queries to SQL Queries
    Posted Dec 04, 2019 08:44 AM
    A couple things:
    1. You can see how AX tables are related to each other in the AOT.   Find the table(s) and expand the relations node, then you can see how they are related.  Here's how InventTrans is related to InventTransOrigin for example.
    2. A simple job will display an AOT query's SQL in an info-log if you already have a working AOT query.  You can also look at the AOT query to see the relations node in case you are using custom relations.
    static void ColbyTestAOTQuery(Args _args)
    Query query;
    query=new query(queryStr(EnterYourAOTQueryNameHere));
    info(query.toString());
    3. The table joins I see in your query that are incorrect are below.  You'll want to review the columns in the views and determine how you want to join to those.
       InventTrans to InventTransOrigin on InventTrans.InventTransOrigin = InventTransOrigin.RecID
       InventTrans to InventTable on ItemID
       InventTrans to InventDim on InventDimId
       InventJournalTrans joins to InventTransOrigin on InventTransOrigin, you look to have InventJournalTrans joining to itself.
    Agility Business Solutions
  • 3.  RE: Coverting AX Queries to SQL Queries
    Posted Dec 04, 2019 03:52 PM
    I​sn't the join to InventDim on InventDimId? Since this is an inner join with no values, the result set would be empty.
    Also do not use reserved words (like Id) as an alias for a table or field.
    Mark Prouty
    Programmer / Analyst
    ANGI Energy Systems
    Janesville WI
  • 4.  RE: Coverting AX Queries to SQL Queries
    Posted Dec 05, 2019 02:16 PM
    If you create a View for the Query in the AOT, it will also create the View in SQL.  You can then look at the View in SQL instead of the AOT, and it will give you a TSQL version.
    Dan Cantley
    Systems Analyst
    Bedrock Manufacturing Co, LLC
    Detroit MI
  • 5.  RE: Coverting AX Queries to SQL Queries
    Posted Dec 06, 2019 01:44 AM
    You need double check your joins. For example InventTrans and InventTable are joined by ItemId; InventTrans and InventDim are joined by InventDimId. RecId does not work in those two instances. There could be more that I couldn't spot out in first glance.
    George Zhao
    PAR Technology
    New Hartford NY
  • 6.  RE: Coverting AX Queries to SQL Queries
    Posted Jan 08, 2020 02:21 PM
    Good Afternoon,
    I modified the query based on the suggestions but I am still having some complications.
    Select S.ACC, S.[Item Number], S.[Name], S.Physical_Date, S.Remark, S.Quantity, S.[Physical Unit Price], S.Total, S.Dept, S.Line, S.Proj From (
    Select Ito.[ItemId] AS 'Item Number',
    Ijt.[JournalNameID] AS 'Name',
    Ijt.[Description] As 'Remark',
    inner join MicrosoftDynamicsAX.dbo.InventTable It
    on Its.ItemID = It.ItemID
    inner join MicrosoftDynamicsAX.dbo.InventTransOrigin Ito
    on Its.ItemID = Ito.ItemID
    inner join MicrosoftDynamicsAX.dbo. InventDim Im
    on Its.INVENTDIMID = Im.INVENTDIMID
    inner join MicrosoftDynamicsAX.dbo.InventJournalTable Ijt
    on Its.RecID = Ijt.RecID
    on Its.RECID = d_1.VALUECOMBINATIONRECID
    on Its.RECID = d_2.VALUECOMBINATIONRECID
    on Its.RECID = d_3.VALUECOMBINATIONRECID
    on Its.RECID = d_4.VALUECOMBINATIONRECID
    on Its.RECID = d_5.VALUECOMBINATIONRECID
    where Its.[DatePhysical] >= '2019-08-01') S
    Allen Broady
    AWNC
    Durham
  • 7.  RE: Coverting AX Queries to SQL Queries
    Posted Jan 09, 2020 08:33 AM
    Update***
    I was able to fix my query but now but I few of my fields did now come in the  Deparment Code, Line Code, Project Code, Ringi Code.
    Select Top 10000 S.ACC, S.[Description 1], S.[Financial Date], S.[Item Number], S.[Name], S.Physical_Date, S.Remark, S.[Vendor Account], S.[Vendor Catalog Number], S.Receipt, S.Issue, S.Quantity, S.[Physical Unit Price], S.[Physical Cost], S.[Financial Cost], S.Reason, S.Dept, S.Line, S.Proj, S.Ringi From (
    It.PrimaryVendorID As 'Vendor Account',
    It.[AW_SPECIFICATION] AS 'Vendor Catalog Number',
    Im.[INVENTLOCATIONID] As 'Warehouse',
    It.[AW_Desc1] As 'Description 1',
    It.[AW_Desc1] As 'Description 2',
    Its.[COSTAMOUNTPOSTED] As 'Financial Cost',
    Its.[DATEFINANCIAL] As 'Financial Date',
    It.[AWFIXEDORDERQTYADC] AS 'FOQ',
    Its.[StatusIssue] As 'Issue',
    Its.[STATUSRECEIPT] AS 'Receipt',
    Ijs.[AWNCINVREASONHTH] AS 'Reason',
    Its.[COSTAMOUNTPHYSICAL] * Its.[QTY] As 'Physical Cost',
    on Its.InventTransOrigin = Ito.RecId
    inner join MicrosoftDynamicsAX.dbo.InventJournalTrans Ijs
    on It.ItemId = Ijs.ItemId
    on Ijs.JournalId = Ijt.JournalId
    on Ijs.LedgerDimension = d_1.VALUECOMBINATIONRECID
    on Ijt.LedgerDimension = d_2.VALUECOMBINATIONRECID
    on Ijt.LedgerDimension = d_3.VALUECOMBINATIONRECID
    on Ijt.LedgerDimension = d_4.VALUECOMBINATIONRECID
    on Ijt.LedgerDimension = d_5.VALUECOMBINATIONRECID
    where Its.[DatePhysical] >= '2019-08-01' and d_1.DISPLAYVALUE LIKE '631%') S
    group by S.ACC, S.[Item Number], S.[Name], S.Physical_Date, S.Remark, S.[Vendor Account], S.[Vendor Catalog Number], S.Quantity, S.[Physical Unit Price], S.[Financial Cost], S.Dept, S.Line, S.Proj, S.Ringi, S.[Description 1], S.[Financial Date], S.[Physical Cost], S.FOQ, S.Issue, S.Receipt, S.Reason
    Allen Broady
    AWNC
    Durham
  • 8.  RE: Coverting AX Queries to SQL Queries
    Posted Jan 09, 2020 04:43 PM
    Hi Allen, I have feeling that you may have some typos in your message. Did you mean "I was able to fix my query now but a few of my fields did not come in the  Deparment Code, Line Code, Project Code, Ringi Code"?
    If that is the case, do you normally enter the financial dimensions at the item side or the offset account side? InventJournalTrans.LedgerDimension is linked to the offset account. If you used to enter FD at the item side you should try to extract them using InventJournalTrans.DefaultDimension.
    George Zhao
    PAR Technology
    New Hartford NY
  • 9.  RE: Coverting AX Queries to SQL Queries
    Posted Jan 10, 2020 04:44 AM
    As a side point, you are missing partition and dataareaid in the where clause and in the table joins.
    If there is only one company(dataareaid) in the environment it wont affect the results, but it will affect performance - these two columns are form the start of pretty much every index in the system (you won't see it from the AOT but look on SQL side).
    Andrew Russell
    direct wines
    Theale
