Negative work quantity
  • 1.  Negative work quantity
    Posted Mar 28, 2019 02:50 PM
    I am wondering why after releasing a load (of a transfer order) to the warehouse, we have negative quantity for some work-lines.
    #AX2012​​
    Reza Pakdel,
  • 2.  RE: Negative work quantity
    Posted Mar 28, 2019 10:18 PM
    Hello Reza.
    When we have detected negative work quantities, usually is because a user made a manual inventory movement, or an inventory adjustment at the location. Have you ckecked the transactions associated to the item and location on Inventory Management -> Inquiries -> On Hand.
    On-hand transactions
    Hope it helps to find out what is going on.
    Mario Castellanos
    Moto Repuestos Monterrey
    Monterrey Mexico
  • 3.  RE: Negative work quantity
    Posted Mar 29, 2019 05:20 AM
    Edited by Reza Pakdel Mar 29, 2019 05:21 AM
    Dear Mario,
    Thanks for your reply. Unfortunately the reason is not the case you mentioned. This issue regularly happens in our warehouse operations.
    It is interesting that it happens just in the warehouses that we have enabled Work-Template set up for them.
    Reza Pakdel
    Ofogh Koorosh Chain Stores
  • 4.  RE: Negative work quantity
    Posted Apr 01, 2019 11:49 AM
    Hi Reza,
    If AX is creating Work lines with a negative quantity, that's a bug. Are you using something on the Work template header to break Work (Maximum total volume, Maximum total weight etc...)?
    Guy Terry
    Portsmouth
  • 5.  RE: Negative work quantity
    Posted Apr 02, 2019 12:43 PM
    Edited by Reza Pakdel Apr 02, 2019 12:43 PM
    Hi Guy,
    Thanks for your reply. About your question, I should say yes. We are using Weight (300 KG) and volume (1.08 m3) simultaneously to break works.
    Do you have any suggestions?
    Reza Pakdel
  • 6.  RE: Negative work quantity
    Posted Apr 03, 2019 02:56 AM
    We saw this problem on AX 2012 R3 CU12, when a Maximum Total Volume was set on the Work Template. I think you'll find it is fixed by KB 3215971, which is included in R3 CU13
    https://fix.lcs.dynamics.com/issue/results/?q=3725808
    Guy Terry
    Portsmouth
  • 7.  RE: Negative work quantity
    Posted Apr 04, 2019 07:20 AM
    Thanks a lot  @Guy Terry . I will try and let you know the result. I appreciate your help again.
    Reza Pakdel
  • 8.  RE: Negative work quantity
    Posted Apr 27, 2020 06:50 AM
    Hello Reza,
    I have faced this issue also, Could you give me the feedback for the suggestion or the assumption that @Guy Terry ​provide.
    BR,
    Ahmed
    Ahmed Essam
    Nestle
