Table Browser Security Access
  • 1.  Table Browser Security Access
    Posted Feb 24, 2020 11:31 AM
    We're trying to grant access to some of our warehouse users to see tables rather than having to find issues through the UI browsing. Even though I have assigned the specific privilege for using the table browser and the specific tables they should have access to, they are getting an error and can't access ANY tables, custom or OOB.
    Any ideas from anyone on what I am missing? We're on 10.0.5 (PU29) but are upgrading to 10.0.8 (PU32) in the next few weeks.
    Kerstin Newman
  • 2.  RE: Table Browser Security Access
    Posted Feb 25, 2020 09:30 AM
    Kerstin,
    Can you verify what error you are seeing when the users try to access the table browser?
    I have verified that the table browser feature itself still works in a PU24, PU31, and PU33 environments (just happened to have those versions).
  • 3.  RE: Table Browser Security Access
    Posted Feb 25, 2020 09:43 AM
    Hi Alex,
    Thanks for your response!
    It does work for anyone with sys admin privileges just fine, but anyone else is getting the below error, even for OOB tables:
    The users are getting the error even though they have the "Open table browser" privilege assigned to their role.. Any ideas as to how I can solve this?
    Thank you!
    Kerstin Newman
  • 4.  RE: Table Browser Security Access
    Posted Feb 25, 2020 10:46 AM
    Kerstin,
    It appears that the Allow Root Navigation option on the sysTableBrowser menu item display is set to No. This means that non-SysAdmins cannot directly navigate to this menu item without a context.
    I'm not sure what the best option going forward would be to a non-SysAdmin user, maybe creating a 'dummy' local extension so you can change this property?
  • 5.  RE: Table Browser Security Access
    Posted Feb 25, 2020 11:24 AM
    Kerstin,
    So I was able to get this to work by doing the following:
    1) Creating a copy of the sysTableBrowser menu item display into a project
    2) Changing the Allow Root Navigation parameter from No -> Yes
    3) Create/assign this copied menu item to a privilege/role (here is an example)
    4) When this is assigned to a user and they navigate to <RootD365FOEnv>/?mi=SysTableBrowserCopy&tableName=<tableName>&cmp=<companyId> they should see the table browser
    (for example to see the UserInfo table: /?mi=SysTableBrowserCopy&tableName=UserInfo&cmp=DAT)
    Feel free to reach out with any questions.
  • 6.  RE: Table Browser Security Access
    Hi, Alex,
    I am interested in doing this as well. Can you please tell me where that sysTableBrowser menu is?
    Polo
    Polo Garcia
    Maple Leaf Farms, Inc.
  • 7.  RE: Table Browser Security Access
    Edited by Alex Meyer 13 days ago
    Polo,
    I'm not sure if you want to try and access it through the user interface or through the AOT so I listed both options.
    The SysTableBrowser is not accesible through a path in the UI you can only get it to their manual URL manipulation using the syntax I listed in my previous post.
    In the AOT, you can find it by searching to sysTableBrowser and selecting the menu item to duplicate.
  • 8.  RE: Table Browser Security Access
    Wonderful! Thank you, Alex!
    Polo
    Polo Garcia
    Leesburg
  • 9.  RE: Table Browser Security Access
    Posted Feb 25, 2020 11:29 AM
    Thanks so much, Alex! We'll see if we can get our developers to build an extension to the table to enable access for non-sys admins. Thanks again for the responses and suggestion, much appreciated!
    Kerstin Newman
  • 10.  RE: Table Browser Security Access
    Posted Feb 26, 2020 05:40 PM
    Hi Kerstin,
    However the method provided by Alex is working, wouldn't it be better to provide a specific form to view the errors more easy? Microsoft might in future decide to remove from or further limit the table browser on the production environment. In that case, I would rather not depend on this form but provide the users a specific form where they can do their specific troubleshooting.
  • 11.  RE: Table Browser Security Access
    Posted Feb 27, 2020 07:52 AM
    Hi André,
    Thanks for the suggestion, I totally agree. We thought the table browser would be easy (because only sys admins tested it before) and a quicker solution for the time-being than building a report or screen for them with the required information. Long-term, that's definitely our goal, we just thought the table browser could provide them with the information in the short-term.
    Thanks again!
    Kerstin Newman
  • 12.  RE: Table Browser Security Access
    Posted 10 days ago
    We had similar discussions for D365. We did not provide the table browser, because the table browser might allow access to all tables. And we do not want that all users can read all finance data, all prices, all HR data in D365, etc.
    Katja Schebler
    NORMA GROUP Holding GmbH
    Maintal
