System directed cluster picking
  • 1.  System directed cluster picking
    Posted Feb 06, 2020 03:28 AM
    We've setup system directed cluster picking for a customer, positions are deactivated on the cluster profile and we use a license plate scan as sort verification type. The warehouse worker will assign work id's to a cluster.
    When presented with the first pick, we scan the item and confirm the quantity. Then the mobile app asks you to put the item on the license plate, but I can't see on which one I have to put my items? I could scan them all one by one until I scanned the correct one, but this is not a good solution. We tried changing the warehouse app field priority, but couldn't find which field is related to the target license plate assigned to the work.
    Does anyone have an idea how to solve this?
    (If I already put an item on the license plate and I pick the next item, then I do see which license plate to put it to.)
    Jonas Delbaere
  • 2.  RE: System directed cluster picking
    Posted 17 days ago
    Hi Jonas,
    I'm struggling with the same issue right now. I was curious if you ever found a solution?
    Thanks in advance.
    Arianna Cochell
    Clients First Business Solutions
    Holmdel NJ
  • 3.  RE: System directed cluster picking
    Posted 17 days ago
    Hello Arianna
    We raised an issue with MSFT and they released a fix in 10.0.11
    kind regards
    Jonas
    Jonas Delbaere
    Avanade
    Merelbeke
