Nazim,
You should have some standard layouts you can import, ex. U.S., Danish, German, Canadian, etc. Is AX2012 going to assign the check numbers? If so, the check number method needs to be fixed and you can assign the first number in the sequence when creating the checks.
MARY LYNN KINCHEN
Sr Systems Analyst
SNF HOLDING COMPANY
Sent: 01-29-2019 01:28 PM
Subject: Check layout set up for Wells Fargo in AX 2012
Hi All
I am looking to set up check layout for Wells Fargo bank on blank paper, Would very much appreciate anyone like to assist with the setttings:
Cash&Bank Management -> Common -> Bank accounts -> set up -> check -> General and Code forms
blank form are attached
Thanks and best regards
Nazim Lalji
Dynamics AX Analyst
