Check layout set up for Wells Fargo in AX 2012
  • 1.  Check layout set up for Wells Fargo in AX 2012
    Posted Jan 29, 2019 01:28 PM
    Hi All
    I am looking to set up check layout for Wells Fargo bank on blank paper, Would very much appreciate anyone like to assist with the setttings:
    Cash&Bank Management -> Common -> Bank accounts -> set up -> check -> General and Code forms
    blank form are attached
    Thanks and best regards
    Nazim Lalji
    Dynamics AX Analyst
  • 2.  RE: Check layout set up for Wells Fargo in AX 2012
    Posted Jan 30, 2019 10:32 AM
    Nazim,
    You should have some standard layouts you can import, ex.  U.S., Danish, German, Canadian, etc.  Is AX2012 going to assign the check numbers?  If so, the check number method needs to be fixed and you can assign the first number in the sequence when creating the checks.
    MARY LYNN KINCHEN
    Sr Systems Analyst
    SNF HOLDING COMPANY
  • 3.  RE: Check layout set up for Wells Fargo in AX 2012
    Posted Jan 30, 2019 03:43 PM
    Thanks Mary
    With each back its different in USA thats why not in standard layout. Like I have Bank of America layout which I can mirror to anyother company. While trying the same BOA layout didnt worked for Well Fargo
    Nazim Lalji
    Dynamics AX Analyst
    Nazim Lalji
    Los Angeles CA
  • 4.  RE: Check layout set up for Wells Fargo in AX 2012
    Posted Jan 30, 2019 04:35 PM
    Nazim,
    I do not know exactly what you are looking for in a check format.  Is it printing in wrong place for Wells Fargo or the wrong information?  Is it a check stock with watermark or blank?  I will need more details on the problems before I can offer any help.
    MARY LYNN KINCHEN
    Sr Systems Analyst
    SNF HOLDING COMPANY
  • 5.  RE: Check layout set up for Wells Fargo in AX 2012
    Posted Jan 30, 2019 08:00 PM
    Hi Mary Lynn
    Check stock is blank paper.  its printing on the wrong place like per Well Fargo measurement.  Attached is check layout form
    please feel free to let me know any question or info require
    Thanks and kind regards
    Nazim Lalji
    Dynamics AX Analyst
    Nazim Lalji
    Los Angeles CA
  • 6.  RE: Check layout set up for Wells Fargo in AX 2012
    Posted Jan 31, 2019 09:16 AM
    Nazim,
    Have you tried adjusting the check start point?  Check printing is standard for US banks, how far is it off?
    MARY LYNN KINCHEN
    Sr Systems Analyst
    SNF HOLDING COMPANY
