Data management import - Map the source to staging
  • 1.  Data management import - Map the source to staging
    Posted Nov 26, 2019 09:53 AM
    Hi Everyone,
    I hope that there is someone that might be able to answer me, as I am not sure what the best way to tackle this challenge.
    I have been tasked with setting up a data import and map the source to staging, but the source file I have received does not contain any headings I can use to reference the entity.
    I hope the one of you can help answer my question.
    Is it possible to do a mapping without the headings as references?
    I have attached an image of my dilemma.
    Patrick R
    Support
  • 2.  RE: Data management import - Map the source to staging
    Posted Nov 26, 2019 03:25 PM
    Hi Patrick,
    You should be able to do that if you set the 'First row header' to 'No' on your source data format.
    Andrew Xu
    Application Architect
    The Jackson Laboratory
    Bar Harbor ME
  • 3.  RE: Data management import - Map the source to staging
    Posted Nov 27, 2019 09:41 AM
    Hi @Andrew Xu
    Thank you for the quick answer, it was exactly what I was looking for. :) ​
    PatRas
    Support-DK
