ZPL Gray scale image
  • 1.  ZPL Gray scale image
    Posted Feb 12, 2020 11:29 AM
    Hello fellow peeps!
    We have a new requirement to print a gray scale logo on a label during the document routing process. We have been successfull at converting a jpg to a black and white ZPL logo, but I don't know how to convert one to gray scale ZPL.
    As always, thanks in advance for your help!!
    Sarah Gabriel
    Operations Business Analyst
    Kai USA Ltd
    Tualatin OR
  • 2.  RE: ZPL Gray scale image
    Posted Feb 12, 2020 06:04 PM
    I guess a normal label printer can only print black, or not (white). Have you got a special label printer that can print colours?
    Guy Terry
    Portsmouth
  • 3.  RE: ZPL Gray scale image
    Posted Feb 12, 2020 06:17 PM
    My guess is that this is a zebra B&W, single ribbon printer. There are a couple of ways to approach this. One is to send the print job as bit map, which usually kills the barcode resolution. Other is to manipulate your image to have interspersed white pixels (like old newsprint). If the printer is 203 or 300 dpi, this might not be very satisfactory. If 600 dpi, should be fine. I guess a 3rd option is to pre-print label stock - yech.
    Mark Prouty
    Programmer / Analyst
    ANGI Energy Systems
    Janesville WI
  • 4.  RE: ZPL Gray scale image
    Posted Feb 12, 2020 06:50 PM
    We have the start of the label!! Under the labelary documentation http://labelary.com/docs.html there are ZPL extensions for simulating color stock. We used the ~BI command. Even more important is that your image must be converted to Base64 scheme. We would used free tool for the conversion. Thank you everyone for your feedback!
    Sarah Gabriel
    Kai USA Ltd
    Tualatin OR
