AX2012 R3 WMS Work templates/Location directives
  • 1.  AX2012 R3 WMS Work templates/Location directives
    Posted Aug 13, 2021 09:41 AM
    We are setting up Work templates for creating Work for shipments.  When we Release the order to the warehouse, is there a way to not create the Work if there is not enough inventory for the order?  Currently it is telling us that "Shipment xxxx was not fully allocated" which means it only created the shipment for the existing inventory.  We would prefer that the Shipment and Work not be created and receive a message the it was cancelled.
    Mark Berg
    Applications Business Analyst
    Bay Industries Inc.
  • 2.  RE: AX2012 R3 WMS Work templates/Location directives
    Posted Aug 15, 2021 09:56 PM
    A few options to check.
    1)On the warehouse, under reservations - do you have 'require full reservation' selected?
    2)If you are using the manual release to WH, you can select a fulfillment policy, after you have added orders to the bottom section of the screen.
    3)Additional options: On your customer master > warehouse fast tab you can set a fulfillment policy and/or check fill entire shipment flag, if you'd like more granular control by customer.
    Curt Killian
    Columbus Global
    FL
