Hi all
I'm trying to set up an AIF to use a barcode scanning solution from a third party vendor. When I'm clicking on a special file, which is very important, the server delivers following error message:
"The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework SDK documentation and inspect the server trace logs."
The Scanners are also delivering the error message "Server Error. Cannot logon to Microsoft Dynamics AX". Everyone should be able to reach the path. I've checked it with various accounts. Is there a feature missing for the IIS?
We are using Dynamics AX 2012 R3 with CU13
Best regards
Stefan
#AX2012
Stefan Botchkovoi
CARBOGEN AMCIS
Aaarau
