(Retail) Financial Dimension values on Retail Transactions
  • 1.  (Retail) Financial Dimension values on Retail Transactions
    Posted May 08, 2019 05:36 PM
    A product has associated Financial Dimensions. When a product is sold, a RetailTransaction record is created. However, we are not able to find which table contains the financial dimension values associated with that transaction. Can someone advise?
    Ken Champion
    Solution Consultant
    Arctic IT
    Metro Atlanta, GA
  • 2.  RE: (Retail) Financial Dimension values on Retail Transactions
    Posted May 09, 2019 12:27 PM
    Hi Ken,
    I had one of my Experts take a look at your question. I hope this helps!!
    RetailTransactionTable has a field called DefaultDimension, that field is a reference to the DimensionAttributeValueSet table, but if you need some code to show the details of the dimensions you can use the following X++ code
    static void displayDimensions(Args _args)
        DimensionAttributeValueSetStorage   dimStorage;
        RetailTransactionTable              retailTransactionTable;
        DimensionStorageSegment             segment;
        int                                 i;
        while select firstOnly10 retailTransactionTable
            info(retailTransactionTable.transactionId);
            dimStorage = DimensionAttributeValueSetStorage::find(retailTransactionTable.DefaultDimension);
            for(i=1; i <= dimStorage.elements(); i++)
                info(DimensionAttribute::find(dimStorage.getAttributeByIndex(i)).Name);
                info(dimStorage.getDisplayValueByIndex(i));
    You can also get the values through SQL, using the RetailTransactionTable.DefaultDimension
    DECLARE @DEFAULTDIMENSION AS BIGINT;
    SELECT NAME, DISPLAYVALUE FROM DEFAULTDIMENSIONVIEW WHERE DEFAULTDIMENSION = @DEFAULTDIMENSION
    Michael Gonzalez
    Account Executive
    Dynamics Resources
    Venon Hills IL
  • 3.  RE: (Retail) Financial Dimension values on Retail Transactions
    Posted May 09, 2019 02:33 PM
    Michael, thanks so much. This is exactly what I was seeking!
    Ken Champion
    Solution Consultant
    Arctic IT
    Metro Atlanta, GA
