Hi Najeem,
We use AX 2012, and as a system administrator you can go to the Area Page under the Home module, and under Inquiries, Workflow go to Workflow History. From that screen you can change the status filter to Pending to find all in review documents, and use the filter by grid on the Document column to find the purchase req that you wish to recall. Once you have found it, you can select it and click the Recall button just above the grid.
Hope that helps!
Wes
Wes Burke
Senior Business Intelligence Analyst
VT Miltope
Hope Hull AL
Sent: Dec 15, 2020 02:18 PM
Subject: Purchase requisition Cancel and delete status by System admin
Hi All
Its a year end and one of task which have to run on behalf of business team is to clean up Purchase requistions in draft and in review status.
Since the requester and the reviewer can recall and delete.
Is there a way that system admin can recall and delete, please advise
thanks and kind regards
