Dear all
I was under the assumption that you cannot change the primary address of a party once set. It seems that I was mistaken.
Some background:We have the Avalara Tax add on installed. I recently found out during a meeting with our implementation partner that it would actually be possible to change the primary address of a party (Contoso dev box without the add on installed).
We think the Avalara add on is "blocking" the changing of the primary address.
Due to lack of knowledge it might be that we have to change some settings. Our implementation partner couldn't answer quickly...
Is someone here using the add on and if so, do you know if it's still possible to change the primary address of a party?
Any input is appreciated!
Thanks in advance and stay healthy!
Best
Andreas
Andreas Mörker
Global Master Data Manager
SIGVARIS
