A property for a journal batch number has more than one value. Data management GL template import issue
  • 1.  A property for a journal batch number has more than one value. Data management GL template import issue
    Posted Aug 26, 2021 02:14 PM
    Hi All
    Trying to import General Journal template through data management, keep receiving below error, any suggestion
    A property for a journal batch number has more than one value. Update the journal batch number properties to be the same for all lines assigned to the same journal batch number.
    Thanks and kind regards
  • 2.  RE: A property for a journal batch number has more than one value. Data management GL template import issue
    Posted Sep 01, 2021 09:53 AM
    Najeem,
    Perhaps you can provide a few screenshots of the data you're attempting to import back into D365 so we could review it. Sounds to me like your initial column, dictating the JGN, is not the same value and is most likely changing values per line.
    Ian Gorman, PMP, MCSE
    MCA Connect
