Hi Nazim,
Have you run the "Refresh cached financial data" routine under the tools menu in MR??
After that the first thing I would check is the source data. Are there any entries for April?? If not MR has no data to present.
Next look at the column definition set up and check what is populated under:
- Book code/ attribute category
- Period
- Period covered
- Attribute filters.
Make sure these settings relate to the budgets you have in the system.
If all else fails as your technical team to reset the data mart in MR.
Kind Regards
Mark
Mark Bailey
Portsmouth
Sent: May 01, 2019 02:27 PM
Subject: Budget column not showing numbers in Management Reporter, AX 2012 R3
Hi All
In 2019, uploaded 2 budgets one in Jan and another in Apr. While running the comparative report (actual vs budget), MR pulls data for actual as well as Jan budget. However when changed to Apr budget it appears blank. Any suggestion to trouble shoot this issue
Thanks and kind regards
Nazim Lalji
Dynamics AX Analyst
