ax 2012 R3 job info log via email
  • 1.  ax 2012 R3 job info log via email
    Posted Apr 23, 2019 03:26 PM
    Hi developers,
    i need to send an email to a group of users, AFTER the job is executed, where i need to list lines from log in the email body.
    So here are two potential problems, where i can use some suggestions:
    1 - i can't add a task to run after the main task of the job, because the BatchHistory table (thats where the info lines live) is committed after the job has finished.
    2- there is an alert option, which would sent email to the user that the job is done, but then i would need to customize the body of the email message that was set up as a template for an alert - which i still cant figure out how...
    any ideas will be appreciated, thanks
    Pedja Nikodijevic
    Express Scripts Canada
    Mississauga
  • 2.  RE: ax 2012 R3 job info log via email
    Posted 25 days ago
    Hi Pedja,
    Can you tell why you think you need to customize the body of the email message? Are you missing some placeholders?
  • 3.  RE: ax 2012 R3 job info log via email
    I would find this useful as well.
    We have a batch process that runs nightly, and the infolog from that process needs reviewed periodically.  Instead of having a sysadmin review it, it would be much better if the infolog results were sent directly to a front-line worker.
    (Note: This batch job always ends in an error state, but not every error in the log requires follow-up.)
    Daniel Zook
    Director of IT
    Lehman's
    Dalton OH
